ONEX #54 Web Site
Date: 1-29-2013
Number of Hours: 4.00
Manual Reference: F05-10
Brief Description: Glare shield fit-up
Moved the rivets to the correct side of the hinge on the seat support angle, F08-01.
Test installed the fuel tank straps, G01-04/05.
On the glare shield, F05-10, smoothed the edges, updrilled holes as necessary, bent the left and right edges on the "Clay Brake" and tested the fit.
Tested fitted the instrument panel, F05-11.
Bent the upper flange of the left forward fuselage panel, F11-01L. Using the brake had a much smoother result than my hand bending used on the right side.
Grand daughter Abby, first to try Onex 54, wears the "Sonex grin"
Glareshield fit-up
Test fit instrument panel
